on 30-10-2023 09:13 PM
My data has suddenly stopped working whilst Iam away
on 30-10-2023 09:49 PM
Are you in the UK or abroad? Are you on PAYG or pay-monthly?
Does your phone show coverage indicators? Are you able to make & receive calls OK?
31-10-2023 12:03 AM - edited 31-10-2023 12:03 AM
@Fletcher88 : Can you make calls & texts?
Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
Often just rebooting the phone is the simple remedy. Also try selecting a network manually rather than auto. Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
on 31-10-2023 07:24 AM
It’s working again I turned off automatic and it worked. Thank you !
on 31-10-2023 07:25 AM
It’s working again now
Thanks for your replying
on 31-10-2023 07:26 AM
Thanks for coming back and letting us know @Fletcher88.
Katie
on 31-10-2023 11:20 AM
