03-07-2023 02:44 PM
My data doesn’t work when I travel to different places although my data roaming is on, how do I fix this?
03-07-2023 04:35 PM
@Mo42 : Where are these different places?
Can you make calls & texts?
Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
If you are on contract, did you activate roaming on your EE a/c before you left UK by texting ROAMING to 150? Having a roaming billing add-on doesn't of itself activate roaming on your a/c.
Often just rebooting the phone is the simple remedy. Also try selecting a network manually rather than auto. Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
03-07-2023 05:50 PM
To add - if you are in the UK, roaming is irrelevant as this refers to using your phone abroad.
If you are abroad, data roaming is a phone setting which still relies on roaming being active on your account. Does your phone show a connection to a local network in your host country?
