29-11-2022 04:53 PM
Why can't I enable roaming retrospectively? I have WiFi access and can verify my identity but not having text message access is preventing me from being able to verify my identity when trying to use several apps.
29-11-2022 04:59 PM
@beejayel : Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
PAYG is auto enabled for roaming as long as you've used the SIM in the UK previously. You won't see any of those settings & don't need to change anything. If outside EU, do you have enough credit for making calls & texts from abroad?
