Roaming
Lisa1882
I'm in USA and have paid for using my phone abroad but it won't connect to a network? Any suggestions?tia
Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
PAYG is auto enabled for roaming as long as you've used the SIM in the UK previously. You won't see any of those settings & don't need to change anything. If outside EU, do you have enough credit for making calls & texts from abroad?
