Roaming
Mr_X
Can you please help me with activation for my roaming? xxxxxxxxxxx xxxxxxx xxxxxx
[Mod edit: Please do not post personal information on the public board. Thanks!]
Schockwave
Hello @Mr_X ,
Welcome to the community,
Where are you at present? Are you in the UK or abroad? Are you on pay as you go or contract?
You may want to take a look here:
https://ee.co.uk/help/help-new/roaming-and-international
If on contract, you should be able to enable it in settings either via My EE app or online. Pay as you go is automatically enabled.
Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
PAYG is auto enabled for roaming as long as you've used the SIM in the UK previously. You won't see any of those settings & don't need to change anything. If outside EU, do you have enough credit for making calls & texts from abroad?
