Roaming
Tola2
I am unable to us my phone in Paris.
@Tola2  Are you a contract customer? If you are have you activate roaming from within your online account?
Leanne_T
Hi there @Tola2
Thanks for coming here.
Are you using a pay as you go or pay monthly plan?
If pay monthly, have you activated roaming in My EE? Go to Menu > Account Settings > Control Content > Roaming abroad and Call abroad, do they show as ticked?
Leanne 🙂
Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
PAYG is auto enabled for roaming as long as you've used it in the UK previously. You won't see any of those settings & don't need to change anything. If outside EU, do you have enough credit for making calls & texts from abroad?
