on 15-08-2022 10:06 PM
I’m travelling to turkey next week and will need add one for roaming for three devices which is going to work out quite expensive and nearly £7 per day.
are there any cheaper options available does anybody know?
on 15-08-2022 10:15 PM
@Kirsty2106 : Add 1 what? Unlike the EU there is no roaming pass for it.
As it is not in EU, you cannot use your usual UK allowances there but will need to pay the charges or buy roaming add-ons as set out in https://ee.co.uk/help/help-new/roaming-costs/countries/turkey-and-northern-cyprus . This is on a per SIM basis.
If you are on contract, remember to text ROAMING to 150 before you leave UK to ensure roaming is enabled on your account.
on 15-08-2022 10:20 PM
Add on the roaming pass …at nearly £7 per day per sim this is quite expensive I had three lines that will need the add on. Surely there is some sort of better package
15-08-2022 10:28 PM - edited 15-08-2022 10:29 PM
Ah, yes, the Travel Data Pass, 1 for each device. No, I've given you EE's tariff for roaming in Turkey.
