Roaming
Teatatu
Hi I need help from a customer service representative asap please. I'm overseas and unable to use my data, calls or messages. Roaming etc is all apart of my plan and activated.
Leanne_T
Hi @Teatatu
Thanks for posting.
If you log log into your My EE account online and go to Menu > Account Settings > Parental and Data Controls > Enable Roaming and also Make calls abroad from the UK > Do they show as ticked?
@Teatatu : Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
PAYG is auto enabled for roaming. You won't see any of those settings & don't need to change anything. If outside EU, do you have enough credit for making calls & texts from abroad?
