on 22-01-2023 05:01 PM
I’m travelling to New York in a few weeks. Once I’ve bought the roaming pass, how do I activate it when I’m there? And do I need to make any setting changes, such as in Mobile Data Options?
I’m a monthly customer and have an iPhone 14 Pro Max. Any advice greatly appreciated.
Solved! Go to Solution.
on 22-01-2023 06:40 PM
Thank you. That’s very helpful.
on 22-01-2023 05:06 PM
Remember to text ROAMING to 150 before you leave UK to ensure roaming is enabled on your account.
on 22-01-2023 05:16 PM
The crucial factor is to enable international roaming on your phone, at account-level - by texting ROAMING to 150 before leaving the UK. That is what allows your phone to connect to foreign networks, without which your billing add-on will be useless.
on 22-01-2023 06:31 PM
Thank you. Should roaming on my Mobile Data Options be turned on? It’s currently off.
on 22-01-2023 06:33 PM
If you wish to use data you will need Data Roaming ON.
on 22-01-2023 06:41 PM
Thank you.
on 22-01-2023 06:43 PM
