on 12-08-2024 02:25 AM
My partner and I have bought a £25 roaming package, for a family trip to Australia. But it doesn't work. Not sure why and we cannot get in contact with E E!!! Ant suggestions of help most welcomed.
on 12-08-2024 04:43 AM
@Burke28 : As you are on contract, did you activate roaming on your EE a/c before you left UK by texting ROAMING to 150? Having a roaming billing add-on doesn't of itself activate roaming on your a/c. Having roaming activated on your EE a/c, not just on your device, is crucial to using your contract SIM abroad.
Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
on 12-08-2024 06:24 AM
on 12-08-2024 08:25 AM
Hi @Burke28 I'd defiantly advise getting in touch with our customer services team so they can investigate why you can't use your roaming bundle, If you're having trouble getting in touch with our customer service team while abroad, you can use the Skype number to give them a call which is 00448000798586
