Roaming not working
Chih
IMG_9782.pngRoaming not working, have tried everything.
It shows the network name and signal bar but no 4G/5G
10 REPLIES 10
@Chih : Can you make calls & texts?
Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
Often just rebooting the phone is the simple remedy. Also try selecting a network manually rather than auto. Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
I'm a monthly pay 33 pounds with no contract.
Leanne_T
Hi @Chih
Have you manually tried searching for a network in your phone settings?
Have you restarted your phone?
Leanne 🙂
There's plenty of confusion in those screenshots.
Numerous mention is made of "paying" and "charging for", which therefore refers to a billing add-on. These reduce the cost of roaming, but are immaterial for enabling roaming itself - which allows access to foreign networks, and without which you won't get coverage abroad.
Reference to "roaming in your phone settings" is presumably to data-roaming, which just tells the phone it's allowed to use mobile data whilst roaming - again, only of use if roaming is enabled on the account.
I can see one message that confirms EU roaming is active, if you are within the EU - then manually selecting an available network and subsequently re-enabling auto selection, should suffice.
I've tried manually and everything still not working.
And now my instagram and email have been hacked because of abroad roaming not working and used outside free wifi
Yes
Christopher_G
What kind of phone are you using, @Chih? Have you tried changing the network mode between 4G and 5G to see if a manual network connection is any better?
Please also try restarting your phone.
Iphone 13pro
i went through all the website
and also restart it plenty of time
Chih
* EE website solution
