on 20-07-2022 03:38 PM
Currently on holiday outside the Eu bought the calls add on but each time I try to make a call I get a message in Spanish then the call disconnect.. I’ve used the phone abroad previously.. just not sure what happened.. and don’t want to call 150 at £2+ a minute
steve
on 20-07-2022 03:35 PM
I’m currently away out of the EU bought the bundle but when we try to make a call we get a message in Spanish before the line is cut… any ideas??
steve
on 20-07-2022 03:52 PM
@3283steve : Where are you? What calls add-on have you bought?
Can you send texts & use data?
Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
If you can't enable the Roaming Abroad and the Call Abroad & Premium Rate settings of your online MyEE, you will need to call CS. Try calling CS on the Freephone no. in my sig. via Skype over WiFi. It should be free.
PAYG is auto enabled for roaming. You won't see any of those settings & don't need to change anything. If outside EU, do you have enough credit for making calls & texts from abroad?
on 20-07-2022 04:17 PM
Hi yes can send text not tried the data as the Wi-Fi is really good so not needed to, we are on contract so didn’t think this would be a problem.
I enabled roaming before we left and confirmed it just now.. we are in the Dominican so bought the 60mins anywhere calls just so my wife can keep
in contact with her mum.
thanks Steve
on 20-07-2022 05:49 PM
A recorded message in a foreign voice when roaming, sounds like something generated by the local network, so standard advice would be to try selecting an alternative local network and see if the problem persists.
You can often do this by restarting your phone, otherwise you may need to use the network connection settings to do a manual selection.
