Roaming in Spain
topcatdsm
I am in Spain until Tuesday 28th. unable to make phone calls and as I am on my own and 80 years old feel very vunerable not being able to contact friends and family let alone emergency numbers . Please can you enable my phone to work!! and add any cost to my monthly Bill I was not contacted by anyone even though you said someone would call me this morning at 9.PM This is a serious problem and should be sorted immediatel
Julie
[Mod edit: Please do not share personal details as your posts are visible to the public. Thanks!]
topcatdsm
I just need someone to unlock my phone so I can make phone calls is that too difficult to understand??? my number is ***
Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
