Roaming in India
db1967
Roaming worked perfectly in Ahmedabad. Then I flew to Mumbai. When I switched flight mode off phone phone said it was optimising One GUI.
I cannot get roaming to work in Mumbai. Can anyone help?
Try selecting a different local network. There may be an issue with the one you're currently connected to.
Having said that, "One GUI" is part of the Android-UI which sometimes appears as part of the boot sequence. Is your phone switched on?
Yes, phoned turned.
EE auto-connect network is Vi India which does not work. AIRTEL selected
manually works, albeit sloooowly.
