Roaming in India
GautamGangoli
I am in India and I would like to buy data. Unfortunately I am unable to access the links to get data.
Leanne_T
Morning @GautamGangoli
Thanks for coming here.
Can you add the data add-on in your My EE app?
Are you on pay as you go or pay monthly?
Leanne 🙂
@GautamGangoli : Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
PAYG is auto enabled for roaming as long as you've used it in the UK previously. You won't see any of those settings & don't need to change anything. If outside EU, do you have enough credit for making calls & texts from abroad?
