on 21-06-2022 09:36 AM
I am in Corfu and when I arrived I got a welcome to Greece text. I later got a welcome to Albania text when I automatically connected to an Albanian network. I have since manually switched this back to a Greek network but I haven’t had another welcome to Greece text. Will I still be charged for Albanian roaming since this was the last text I received?
on 21-06-2022 09:58 AM
@Sophie145 : As long as you are connected to a Greek network you will be charged according to EU roaming.
on 21-06-2022 06:03 PM
Hey @Sophie145
As per the reply above, you'll be fine when roaming on a Greek network.
What I would recommend doing though (as Corfu is close to Albania meaning you can pick up their networks - as you know) is do a MANUAL network search and select the Greek network you've been using (Cosmote or Wind) to stop it jumping onto an Albanian network.
