on 25-09-2023 03:44 PM
I am currently in Barbados and wanting to get a daily roaming add-on. I responded to the EE text on arrival but on trying to buy data I have a message ‘You are currently blocked from buying additional data - speak to the account holder’. But I am the account holder!
Any ideas to get around this?
Paul
on 25-09-2023 05:08 PM
Thanks for coming here.
Are you set up as the bill payer here in the manage numbers section of your My EE account? To purchase the add-on.
Thanks 🙂
on 25-09-2023 07:05 PM
Hi Leanne
Thank you for your reply to my question.
Yes, I am the bill payer and the account is in my name.
Can I go into my ee account to get a daily roaming add on?
Paul
on 26-09-2023 08:11 AM
Yes, you should be able to. Do you have an active spend cap that could be blocking the purchase?
on 26-09-2023 07:57 PM
on 27-09-2023 08:03 AM
Hi @PaulGlover1953,
Just to double check, if you log in to My EE and go to manage numbers, do you show as the bill payer or a user?
on 27-09-2023 02:24 PM
on 27-09-2023 03:08 PM
