on 07-06-2023 02:05 PM
Hello! I am a pay monthly EE customer and I have Roaming included in my plan. The problem is I am abroad and i have no service. Signal bar is full on my screen but no Roaming. Because of this I can't use mobile data either. Frustrating as I'm paying around £100 monthly and in top of not having any connection it is also so difficult to reach EE customer service. I can't call EE because I have no service, I can't use the App because there is always some maintenance issues, I can't message EE because messaging is currently unavailable. Now, anyone knows how to deal with this? 🙂
on 07-06-2023 03:59 PM
Hi @MariaR
Welcome to the community.
Where in the world are you? Have you tried manually connecting to a different available network?
07-06-2023 07:35 PM - edited 07-06-2023 07:36 PM
This is contradictory. Roaming refers to using your phone abroad, and to do so the roaming facility enables your phone to connect to foreign networks. All that is included in your plan is the cost of some calls abroad.
If you have signal bars showing, then you are connected to a foreign network and are roaming. Depending on the nature of your issue, there may be a local network issue which can often be solved by manually connection to alternatives.
on 07-06-2023 07:53 PM
on 07-06-2023 07:59 PM
This sounds like a potential device quirk that signal is shown when you aren't connected a local network, which likely means that roaming isn't enabled on your SIM.
This will prevent any network-based service working - calls, texts & mobile data. It can only be resolved by CS enabling the roaming facility - you will need to either use another working phone, or a web-calling app such as Skype.
on 08-06-2023 02:43 PM
on 08-06-2023 02:44 PM
Thanks for coming back and letting us know @MariaR
Leanne 🙂
