Re: Roaming
Amanda1271
How can I get someone to contact me. I'm abroad and my phones not working.  I only have WhatsApp.
Can some one from customer care please sort this issue out
It's not any billing package or add-on that you need, it's the roaming facility to be enabled. If that is inplace on EE's network, then this is likely to a be local network issue.
Toggling flight mode and manually selecting an alternative local operator usually resolves this.
7 REPLIES 7
It sounds like you've travelled abroad without enabling roaming on your phone - this will prevent it connecting to any foreign networks.
Are you on PAYG or pay-monthly?
If PAYG - Phones are auto-enabled for roaming once they are used in the UK first
If pay-monthly - if you didn't enable by texting ROAMING to 150 before leaving the UK, only CS can now enable it for you. You can try a live-chat, otherwise will need to call them from another working phone or perhaps a web-calling app such as Skype.
354-
Star Contributor
Star Contributor
Yes, Skype is the way!
Amanda1271
My phone had been checked. I have the correct package as I go away a lot. I called up on Wed and get them to check it was in place
Hi there I'm monthly. Never had a problem before.  Always use it abroad
How do I sky them
James_B
EE Community Manager
Hi @Amanda1271,
Did you try selecting another network manually?
For iPhone - Settings > Mobile Data > Network Selection > Turn off Automatic
For Android - Settings > More Networks > Mobile Networks > Network Operators > Tap OK
