Re: Phone won’t connect to a network in the USA
Azulitos
Yes and I still can't connect
@Azulitos : Are you on contract or PAYG? Had you used that SIM for making calls or texts in UK before you left to go abroad?
Often just rebooting the phone is the simple remedy. Also try selecting a network manually rather than auto. Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
