on 05-02-2023 02:42 PM
Data not working in pakistan
05-02-2023 02:47 PM - edited 05-02-2023 02:48 PM
@78600 : Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
Often just rebooting the phone is the simple remedy. Also try selecting a network manually rather than auto
on 05-02-2023 04:10 PM
Do you have coverage indicators of a Pakistani network?
If yes, are you able to make & receive calls if you do?
