on 18-07-2022 04:34 PM
I’ve increased my spend cap but I can’t find a way to activate my roaming. I’m currently in Spain but I can’t use my data or make calls I think, so wha do I do now?
on 18-07-2022 04:54 PM
@Daves_hd1 : As you are on contract, did you activate roaming on your EE a/c before you left UK by texting ROAMING to 150? Having a roaming add-on doesn't of itself activate roaming on your a/c.
If you can't enable the Roaming Abroad and the Call Abroad & Premium Rate settings of your online MyEE, you will need to call CS. Try calling CS on the Freephone no. in my sig. via Skype over WiFi. It should be free.
