on 03-06-2024 06:09 PM
Before coming abroad this morning I forgot to purchase what I need (cost about £10/12 I think) to enable me to use my phone in Spain. How can I rectify this?
Solved! Go to Solution.
on 03-06-2024 06:48 PM
If you are on pay-monthly and now find yourself abroad without having enabled roaming, your only recourse will be to contact CS to request it activated. You can either contact +44 7953 966150 from another working phone, or +44 800 0798586 using a web-calling app such as Skype over WiFi.
