Problems with receiving SMS OTP verification codes from international numbers
Theo77
I know that there have been many threads already about this, but I have not found a solution so I am posting my own question.
I have been unable to receive almost all OTP's from international numbers since February 2023 (whether I'm abroad or in the UK). This specifically effects international numbers as most OTP's from UK numbers/companies work.
I have not changed anything on my side so I assume EE is blocking these messages as suspected spam.
One interesting example of this problem is logging in to some public WiFi networks abroad. They require me to enter my phone number, and then enter a code that is sent via text message.
As I try and connect to the same networks each year I can see how this situation has evolved:
• Before I ported my number over to EE from iD in Summer 2021,, I always received these texts within seconds
• In 2022 logging onto these same networks I mostly received the texts (one failed)
• In 2023 logging on to these same networks one was successful after a long 45 minute wait but many were not
• In 2024 none of these networks at all had a text that got through. I had to connect to WiFi using often very complicated alternative methods.
Do you think EE's spam detection systems are just getting stricter and stricter? Is there any solution without changing phone network?
14 REPLIES 14
Christopher_G
Hi @Theo77
What kind of phone do you use? It would be interesting to know if this same thing happens when you put your SIM in another phone. Are you able to try that?
Theo77
I'm currently using an iPhone 15 Pro and also had this same issue on my iPhone 12 Pro before I recently upgraded. I don't think its the phone at fault as an eSIM from another network in the same phone always receives codes from these same public WiFi networks and from other websites within seconds. I don't have an Android phone I can test with.
Christopher_G
OK, thanks @Theo77
I recommend speaking to our Technical Support team so that they can take this information from you, check everything on your account from our side and raise it further, if needed.
My understanding is that guidance on avoiding the risk of false-positive blocks on inbound foreign-SMS is available to all senders.
Operators are in something of a no-win situation here. Be seen to encourage spam-SMS on the one-hand, versus risk criticism for vastly reducing the problem because some genuine senders (who potentially don't follow guidance) get blackholed.
At least one other operator is now introducing a very similar system to that of EE.
Theo77
That's very interesting to know. If you don't mind please do tell me which operator so I don't accidentally get a backup SIM from them.
Do you think customer service would be able to decrease the amount that are blocked for my account? Or is this unlikely and should I continue with the strategy of needing multiple SIMS active before I try to connect to one of these networks?
Out of interest if you'd like to know these networks include fairly busy and well-known locations such as:
• Zurich Airport and Geneva Airport (although one can technically instead get an access code through physically registering with ID/boarding pass at both, it just takes a lot longer)
• All networks in Switzerland using the Swisscom PWLAN system (including major supermarket chains, city-wide WiFi, hotels, motorway service stations and several major banks)
jusmee
Same problem here. Can no longer receive OTPs from UK when I am in Philippines. No problem ever previously. Problem started August 1st. Using android on a Samsung Galaxy S21 Ultra. Same problem when I tried my sim in another unrelated phone so it must be an EE problem? PLEASE HELP
Katie_J
Hi @jusmee
Thanks for coming here.
Can you receive OTPs when you are in the UK OK?
Katie
No problem in UK. Also no problem in Philippines until recently.
jusmee
Tried using VPN also but no help.
