on 18-01-2023 09:42 PM
I am in the USA and cannot make any calls. I cannot contact EE to sort
I have a business monthly account.
Very poor I cannot sort with EE
Solved! Go to Solution.
on 18-01-2023 11:04 PM
Did you enable international roaming before leaving the UK? That allows your phone to connect to foreign networks which inturn allows you to make calls, send texts & use mobile data.
Without roaming being active, then an inability to connect to foreign networks is expected. Try contacting EE using Skype over a WiFi-connection on +44 800 0798586
