Poor calls in MK45 area for several weeks
philipj451
for a couple of weeks now there has been poor network status giving poor calls that drop out and hang up randomly. I keep checking the Network Status Report for my postcode MK45 3HA and I tell it that my phone is an iPhone13.
Every time it has said that there is a problem being worked on and that normal status should be resumed within 16 hours, well that has been for a couple of weeks!!!
Please could somebody tell me what is the problem and when will it be fixed ?
Are you waiting for a replacement part?
Are you having trouble getting onto the land where the mast is?
thanks
PhilipJ
6 REPLIES 6
Northerner
Hi @philipj451
Can you use EE WiFi calling service?
https://ee.co.uk/help/help-new/getting-started-and-upgrading/using-your-phone-features/how-do-i-use-...
If it's a parts issue then you'll just need to wait. Once repaired and if you're registered then your receive notification.
To contact EE Customer Services dial 150 From your EE mobile or 0800 956 6000 from any other phone. You can call Freephone +44 800 079 8586 on Skype
thanks
PhilipJ
Whilst I can fully appreciate your frustration, there are a multitude of reasons why some network faults are not resolved as promptly as all end-users would like. A third-party dependency is a common one, but not necessarily the reason here.
If you have a 4G-calling device, it may be worth dropping your phone to 3G (or disabling) 4G as a test. I would not recommend anyone do this for anything other than workaround/testing purposes, but if the issue is on the 4G-layer, then forcing your calls onto legacy techs such as 2G/3G - if available - may provide a temporary workaround.
philipj451
Hi, yes I can but that only works for my outgoing calls.
When I have a call coming in it is on the network and I get poor quality and dropping.
I'm not complaining, I just wanted to know if there was more information
PhilipJ
philipj451
Hi bristolian,
True, but a bit more information on the Network Status site would be helpful rather than just saying "We're on it. We expect good service within 16 hours, but some fixes take a little longer", it gets a bit tedious after 2 weeks.
PhilipJ
I'm not sure which of your comments were aimed at which suggestions, but WiFi-calling works for incoming calls as well as outgoing. It allows you to use your phone as normal anywhere you have a working WiFi signal.
I can appreciate your frustration with delays to fault fixes, the status checker is the best way to get updates.
philipj451
Hi bristolian,
again thanks, I didn't know that about WiFi calling for incoming. Guess this technology is getting so clever it's running away from our understanding 🙂
regards
PhilipJ
