Phone not working in America
princesskew
Read more
Read more
My phone is working in America unless I have WiFi. I can’t call EE as it has no service at all! Please help
@princesskew : Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
PAYG is auto enabled for roaming as long as you've used the SIM in the UK previously. You won't see any of those settings & don't need to change anything. If outside EU, do you have enough credit for making calls & texts from abroad?
