10-10-2021 10:41 AM
I am going to Greece for a week, can I use my PAYG data and calls, or do I need to buy a roaming pack?
10-10-2021 11:50 AM
Great news is that you can roam in Greece and use the same data and calls bundles you use in the UK.
Enjoy Greece 👍
10-10-2021 12:02 PM
Hi @n1gelwebb
Thanks for coming to the community 🙂
You can use your minutes, texts and up to 25GB of data. Our fair usage policy (given in your roaming plan) means you can use up to 25GB of your data within 48 EU/EEA destinations.
If you're travelling near Turkey, you’ll get charged international roaming rates if your device connects to a Turkish network.
To avoid charges, check you're on the right operator in your device settings whilst abroad.
Hope you have a lovely time in Greece 🙂
10-10-2021 12:17 PM
You can also check roaming costs for any country, on PAYG & pay-monthly, using the roaming costs tool here
PAYG phones need to be used in the UK first, before they will - automatically - work abroad.
