No signal in Hungary
Iain07
im currently in Budapest and I have no signal I think roaming is activated on my account. I cannot phone out to EE. Can anyone help?
Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
I can’t get into Skype because they are sending me a code via txt
Can't you install Skype not on a phone? Then they will use email.
