No Network in Turkey
KHadfield
I cannot make calls, texts or access dAta in Turkey.  My phone shows Turkcell and full bars in the top corner but when I try to call it beeps 4 times and goes dead.  It worked fine when I initially arrived for about 6 hours then stopped working. If I connect to Wi-Fi I can make what’s app call and access data but I need to receive urgent calls and texts - Any advice?
if your phone is a business-paid line, then your account contact is your employer. It is they who are responsible for the account & phone, and only they who can resolve this. You are doing the right thing by contacting them.
This community can give general advice but doesn't have access to individual accounts.
7 REPLIES 7
James_B
EE Community Manager
Hi @KHadfield,
Do you have a spend cap on your account?
It is a business phone and I am told not
Sent from my iPhone
[Mod edit: Please do not post personal information in this public forum. Thanks]
James_B
Hi @KHadfield,
Have you or the person that managed the business account checked this with Customer Care?
I am told so, I am communicating with my employer as I am unable to contact them direct
[Mod edit: Please do not post personal information on the public board. Thanks!]
James_B
Has your employer contacted their account manager/business customer care team @KHadfield?
Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
PAYG is auto enabled for roaming as long as you've used the SIM in the UK previously. You won't see any of those settings & don't need to change anything. If outside EU, do you have enough credit for making calls & texts from abroad?
