No Data is spain
Burston84
I have a data cap enabled and I also have data roaming in. I have a data plan of £2 a day whilst abroad but it doesn’t seem to work. Everything is correct and should work  but doesn’t
@Burston84 : Can you make calls & texts?
Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
PAYG is auto enabled for roaming as long as you've used it in the UK previously. You won't see any of those settings & don't need to change anything.
Hi
No I can’t send texts either. I could on day one all worked then all of a sudden we erything has stopped working. I had no issues when I went to Greece in July. Only thing that’s changed is I changed my contract. I’m sim only
Regards
Ian
xxxxxxxxxxxxx
[Mod edit: Please do not share personal details as your posts are visible to the public. Thanks!]
Sent from my iPhone
