28-03-2022 12:36 PM
Why do my msgs only send when using WiFi or data ?
I'm a pay monthly
Using galaxy s21 had the same problem with my old phone aswell?
I have full bar coverage when sending.
28-03-2022 12:53 PM
What msgs are you sending? Using what messaging app? Could they be MMS?
28-03-2022 01:06 PM
@Dellano1 If there only going via Wi-Fi or data they are not text messages they are instant messages and these only send/receive when using a internet connection be that Wi-Fi or cellular data.
28-03-2022 01:14 PM
28-03-2022 01:21 PM
What is "a msg" called?
An ordinary text msg does not use or need data or WiFi. So they must either be MMS's or some instant messaging like WhatsApp.
28-03-2022 01:38 PM
@Dellano1 Are you using the text message app or a different app ? Is this a new device? If it is what was your old device?
28-03-2022 08:36 PM
28-03-2022 09:09 PM
Are you using emotions/emojis in your texts? That would turn them into MMS.
Look in your Messaging app for something like Settings > More Settings > Multimedia Msgs > Set Restrictions & set it to Restricted or Warning.
