Mobile problems in germany
Grahamperry99
Not sure why can’t access internet at all in berlin
13 REPLIES 13
Does your phone have coverage indicators of a local network in Germany?
If you do, then roaming must be enabled and the next test is whether you can make/receive calls and send/receive text messages
If you don't, then it's likely you have a problem with your roaming facility which may not be active. In this case - are you on PAYG or pay-monthly?
Leanne_T
Hi @Grahamperry99
Can you make calls and send texts?
What happens if you try and use any internet services in Berlin?
Leanne 🙂
Just internet I can’t access when not on wifi
Sent from my iPhone
Leanne_T
Thanks for coming back to me @Grahamperry99
Can you try manually selecting another network to see if you can use data?
Tried the three networks available. No luck. Called ee. They put me through to tech support. Had a 20 min conversation then was cut off and they didn’t call back
Sent from my iPhone
Leanne_T
I am sorry to hear this @Grahamperry99
If you can call us again when you get the chance the team will get this looked into further for you.
Leanne 🙂
Thanks. Will have to be this evening when I’m in hotel as just hopping between cafe wifi at moment
Sent from my iPhone
Leanne_T
I see, @Grahamperry99
Let me know how it goes and enjoy your day.
mailjackhorrey
Hi Graham, sadly the EE roaming service isn’t very good in Germany I have problems all the time. Which network are you roaming with?
