on 31-07-2023 09:14 AM
I’m currently in Majorca. I have a roaming pass active. I have roaming active on my phone. I cant make calls or texts.
I cant call or text EE for help because it won’t allow.
can someone advise how to contact them or what I can do
Solved! Go to Solution.
on 31-07-2023 02:19 PM
Thanks @Bgillham
This would need to be looked into for you, please call us from any other phone on +44 7953966250 and the team will be happy to help.
on 31-07-2023 10:26 AM
Hi @Bgillham
Did you text ROAMING to 150 before travelling?
Can you manually search for a network in your phone settings, does your phone show any available?
on 31-07-2023 12:42 PM
Hi Leanne,
I didn’t text roaming before I left because I have done it previously.
I can search for networks, am connected to a network and can use data no problem.
I can receive calls but not make calls or send texts.
thank you
on 31-07-2023 01:18 PM
Thanks @Bgillham
Can you try and connect to a different network, does this work calls and texts?
Can you use data when not connected to WiFi?
on 31-07-2023 02:03 PM
hi Leanne,
I have tried to connect to a different network and it’s still the same.
yes, I can use data without wifi.
becky
Thanks @Bgillham
on 10-04-2026 09:36 AM
Im in exactly same situation.
on 10-04-2026 11:52 AM
Hi @Aaaaaaaaa8,
Welcome to the Community!
Are you able to call our team on +44 7953966250 on another phone, as @Leanne_T has suggested above?
Rach
