Is it
Nankhoma1
Is it possible to unblock 🚫 blocked numbers
Schockwave
Hello @Nankhoma1 ,
Welcome to the community,
If it is an Apple phone, then click on settings and scroll down to phone, you will see blocked contacts, you should be able to do so.
I suspect Android is the same, but as I do not have Android, I cannot confirm this.
Android allows you to view all the numbers you have blocked under your call settings, you can then remove any numbers if you want to.
