29-01-2024 04:30 PM
For some reason since I've changed from iphone13 to 15 and moved to eSim my voicemail is not working.
I've long pressed 1 and called 222 but the numbers just cut out, I've also messaged VM ON and OFF and restarted my phone many times but still not working.
I have spoken to technical support and they couldn't work out what the problem is.
Anyone had any luck in getting their voicemail to work?
29-01-2024 05:26 PM
What did CS offer by means of resolution? Given that you were calling them for help in resolving a problem, did they leave you high & dry? Or offer to escalate the issue as necessary?
If they declined to deal with your issue and effectively left you high & dry, I'd consider that grounds for complaint.
30-01-2024 01:40 PM
Well CS was supposed to call me today at 12.30 with an update but as expected there was no call.
Still no voicemail and no one knows why!
30-01-2024 03:51 PM - edited 30-01-2024 03:52 PM
Hi @sheetprab
I am sorry to hear you have not been contacted, I would suggest calling us on 150 and the team can check your account and provide an update on your voicemail issue.
Let me know how you get on.
