I am abroad but forgot to register for roaming,emergency calls only need to roam
Disneyfox
Often just rebooting the phone is the simple remedy. Also try selecting a network manually rather than auto. Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
