08-03-2022 05:22 PM
Hi There
I need help I am out of UK and I can not use my phone.
I can not make any call, no sms, no internet.
I try to call the umber of EE to call form abroad but I could not speack with anyone.
Could you please help me urgently?
many thanks
08-03-2022 06:06 PM
@SimoZ : Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
Often just rebooting the phone is the simple remedy. Otherwise try logging into your MyEE account online & go to Menu > Account Settings > Parental and Data Controls > Roaming Abroad and also Call Abroad and Premium Rate. They will show as ticked if roaming and calling abroad is activated. If they are not ticked, can you activate these settings?
If you can't enable the Roaming Abroad and the Call Abroad & Premium Rate settings of your MyEE, you will need to call CS. Try calling CS on the Freephone no. in my sig. over Skype. It should be free.
PAYG is auto enabled for roaming. You won't see any of those settings & don't need to change anything. If outside EU, do you have enough credit for making calls & texts from abroad?
