How long does roaming take to work?
Nello1234
Jon_K
Former EE Employee
Hi @Nello1234.
Are you abroad now?
Is Roaming activated in your My EE Account?
It can take up to 24 hours to fully activate.
Jon
Nello1234
I didn't switch roaming on until I got the Spain. I was advised it may take over 24 hours (on this board) but it's been well over that time frame now.
Can't get through to EE on any numbers provided (trying on my wife's phone).
I can't even search for other networks.
Can anyone help please?
@Nello1234 : Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
PAYG is auto enabled for roaming as long as you've used the SIM in the UK previously. You won't see any of those settings & don't need to change anything.
As I said in the post, I was in Spain when I switched roaming on. My
mistake.
