How do I contact ee from abroad about my roaming not working
HAR14
Hi
i I need help from we but cannot find a way to contact them.  I was able to roam in Europe but am now in South America and cannot call or use data therefore a phone number is no use and the  re is no option to chat .
At a loss
@HAR14 : Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
Often just rebooting the phone is the simple remedy. Also try selecting a network manually rather than auto. Otherwise you need to call CS to get your roaming activated.
Thanks a lot.     I didn’t type roaming as had done so previously and was able to roam on route to South America.   I’ve tried the numbers for CS but all terminate without an answer.   Looks like I’m just going to be tied to hotel WiFi access only 😔.
thanks again.
Sounds like you had EU-only roaming enabled, thus being outside the EU amounts to no-roaming.
You can either contact +44 7953 966150 from another working phone, or +44 800 0798586 using a web-calling app such as Skype over WiFi.
You should be activated for global roaming unless in the meantime you restricted it to EU roaming.
HAR14
Thank you
