Help with roaming
Sophiapink41
im in the usa and my phone has not started the roaming that I set up, I can’t dial out or even call the number provided.
any help?
Alex_M
Star Contributor
Star Contributor
Hi @Sophiapink41 ,
Are you on a pay monthly plan? If so, did you text ROAMING to 150 before leaving the UK?
Thanks,
Alex
 If I solved your issue, please click the solution button below!
 If you found my post useful, click the thumbs up button!
 To speak to EE, call 150 from your EE mobile or +44 800 079 8586 (freephone) or start a live chat.
Useful Links: My EE | Live Chat | Bills | Usage | Network Coverage Checker | Abroad | APN Settings | PM
@Sophiapink41 : Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
If you are on contract, did you activate roaming on your EE a/c before you left UK by texting ROAMING to 150? Having a roaming billing add-on doesn't of itself activate roaming on your a/c.
Often just rebooting the phone is the simple remedy. Also try selecting a network manually rather than auto. Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
