on 22-06-2022 01:33 PM
Hi guys,
I have a Samsung 21s and had problems texting as the error 0 code kept coming up.
I pressed the 4 dots on the search bar which came up with settings which I pressed on and went to features.
There was a choice right at the bottom where ir says do you want to change sms messages to text I pressed on that button and it worked.
Very happy person!!
on 22-06-2022 03:12 PM
Hi there @Sazza75
Thanks for coming here and sharing the solution you have found 🙂
If you need any further help please let us know.
