Data
Dilmah
Hi, I’m wondering what the charges are for Tenerife? Am I able to use my normal data or is it an extra data roaming charge. Thanks
@Dilmah : As it is part of EU, you may use your usual UK allowances there with up to 50 GB (contract) or 25 GB (PAYG) data per billing month if you have more. If on contract & your contract started after 07/07/2021 there'll be a £2 / day charge for using your UK allowances in EU or you may buy the Roam Abroad Pass for £10 / month.
If you are on contract, remember to text ROAMING to 150 before you leave UK to check roaming is enabled on your account.
