Data roaming Japan
ruggshack
so my son has a sim connected to my account, we have had this for years.
he has gone to Japan and now cannot access his online banking as no OTP’s can be received.
urgent help required.
he will run out of cash today
Leanne_T
Hi there @ruggshack
Thanks for coming here.
Is his number on pay as you go or pay monthly?
Can he receive other texts and calls?
Leanne 🙂
@ruggshack : Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
PAYG is auto enabled for roaming as long as you've used it in the UK previously. You won't see any of those settings & don't need to change anything. If outside EU, do you have enough credit for making calls & texts from abroad?
