Data Roaming
tynsk01
Hi all,
Will my data roaming work as normal in UAE? Or what do I need to get for this country to use data on my phone?
@tynsk01 : Outside the EU, you cannot use your usual UK allowances there but will need to pay the charges or buy roaming add-ons as set out in https://ee.co.uk/help/mobile/roaming/roaming-costs/countries/unitedarabemirates.
If you are on contract, just remember to text ROAMING to 150 before you leave UK to ensure the roaming ability is enabled on your account.
If you are on PAYG, make sure you have already used your PAYG SIM to make a call or text in the UK.
