09-02-2023 05:33 PM
I travel to and from Bristol to Birmingham on the train and the connection with EE seems to be getting progressively worse. Patchy at best for 4G and constantly dropping
is anyone else experiencing this or concreting moving to another provider as this is just dreadful?
thanks
09-02-2023 06:14 PM
Hi @Critchdb
Does the problem occur when you're on the train and moving?
Do you have any problems when you're in either Bristol or Birmingham?
Jon
09-02-2023 06:25 PM
09-02-2023 06:25 PM
Tricky to advise without specifics really - I have first-hand experience of performance issues in particular scenarios recently, but yours sounds a more general issue. Do you know any friends or relatives whose phones have similar problems? That would be a good test to eliminate your phone vs network, as a cause.
You would be wise to test alternative operators before assuming they would automatically be better.
