Cant call out from tenerife
Sheeds
Hi all.
IIv set up my roaming b4 i flew to tenerife, but now here i cant call anyone.
Ihave no signal bars just a cross. Ideas welcome please.
@Sheeds : Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
If your phone is showing a cross where signal bars should be, one of two things is happening.
1: You have roaming activated but there's a problem with the specific network your phone is trying to connect to. Manually selecting an alternative often resolves.
2: Roaming is not activated on your SIM, which has been covered in the reply above.
Sheeds
Cheers xray.
I v just texted roaming to 150.
Big thanks geez yr a star.
Thanku
