on 28-09-2023 04:38 PM
I can receive calls but cannot make outgoing calls connect. Can’t speak to EE as cannot call 150!!!
on 28-09-2023 05:07 PM
Hi @Rlang1611
Thanks for coming here.
Have you tried to manually search for another network in your phone settings to see if any show available and you can try and connect to?
If so, can you make calls if you select another network?
on 28-09-2023 05:31 PM
on 28-09-2023 05:36 PM
Are you in Greece wanting to use your phone for calls? This is roaming.
Or are you in the UK wanting to receive calls from Greece? This is normal usage and the source of the call is immaterial.
If you are roaming, does your phone show a local network connection?
on 28-09-2023 05:44 PM
on 28-09-2023 06:00 PM
