19-11-2021 09:16 AM
I use call divert from my landline to my mobile in the UK. I'm going to the Canary Islands and wanted to know if I divert my landline to my mobile as usual can I receive the call and what is the cost for this
19-11-2021 11:36 AM
As it's in the EU receiving calls will be included in your calls allowance.
03-12-2021 08:09 PM
If you're asking about the call charges for the divert to your mobile by your landline provider, you will be charged at the usual rate or unless you have a call allowance it will come out of that as your landline will be diverting to a normal UK mobile number.
Some people think that if you call a UK mobile number that is roaming in another country that you will be charged international rates, this is not true as you are simply dialling a UK number.
