Angry, ruddy angry
Raysur52
Message stating 'Not registered on network' for two days now. To try and talk to someone is impossible and losing patience fast.
Several possible reasons for this.
1: Problem with your account causing your service to be suspended. Are you on PAYG or pay-monthly?
2: Local loss of service meaning lack of EE coverage - check either by performing a manual network search or using "check status" on https://ee.co.uk/help/mobile-coverage-checker
Northerner
@bristolian
  • Could be the phone is barred if purchased outside of EE.
  • Could be abroad.
@Raysur52 will need to provide some more information.
Blacklisting is a fair point.
Being abroad without roaming would - technically - fall under suspended service. Valid to mention nonetheless!
@Raysur52  If you’re in the UK have you tried checking to see if WiFi calling is work for you ?     If this doesn’t work then you probably have a SIM card issue if it does work have you checked to see if there is a network issue in your area ?  You can use THIS and click the check service status tab.
